Other Parts Discussed in Thread: TPS54140,
Team,
Is the criterion of skipping mode between TPS54140 and TPS54240 the same? Or they're not the same?
Since system requirement in customer side, the original TPS54140 is changed to TPS54240 however, as test result customer found the communication problem on MCU when TPS54240 is used.
In the waveform below, it looks the TPS54240 enter into Pulse Skipping mode, but TPS54140 is NOT.
Please help to clarify this issue, and offer suggestions. thanks.
TPS54140 Waveform:
SD300-> PH pin
TPS54240 Waveform:
Schematic:
