TIMING RESISTANCE for TL2842B
Other Parts Discussed in Thread: TL2842B, TL3842B, TL3842
I would like to know about "TIMING RESISTANCE (RT)" for TL2842B.
Could you please help ?
My customer says he wants to use RT = 1k Ohm in his application.
Looking into "TIMING RESISTANCE vs. FREQUENCY" graph in page12 of datasheet,
SLVS610B, there are data for RT between 3k to 100k Ohm, but not for 1k Ohm.
On the other hand, "MAXIMUM OUTPUT DUTY CYCLE vs. TIMING RESISTOR" graph
shows data for 1k Ohm.
He is wondering if "1k Ohm" should not be used for RT or not.
(RT must be higher than 3k Ohm ???)
If 1k Ohm is acceptable, he wants to get TIMING RESISTANCE vs. FREQUENCY
graph with data covered for RT = 1k Ohm.
Please advise.
Thank you in advance for your help.
