Other Parts Discussed in Thread: TPS25854-Q1, TPS25862-Q1
Hi Team,
I would like to know if it is possible to use Type C only and disable Type A? does disable port B by pulling PB_EN low work? This part is designed for dual ports andIo only require one. what happens if you don't connect the second port? Are there problems here or can this be left open/disabled?
Thanks!
Marvin
