Hello TI,
I have designed a circuit with the TPS48110. With this I would like to switch a MOSFET and monitor it. To test the overload protection I have connected the output to an electronic load. In doing so, it destroys on every test and has done so 6-8 times. It has only worked in one setup so far.
In addition, I also have your test board for the IC here. With this the testing with the setup works without problems.
Can you help me and say where the error is?
Thanks for your help
