The tps3106k33 nrstvdd and nrstvsense , What is the maximum value of Isink ? And maintain time
Please kindly elaborate on and clarify your question. Thank you.
HI Masoud:
I want to know the maximum value of nrstvdd and nrstvsense about tps3106k33 .
How long does the maximum value continue
On TPS3106, both RSTVDD and RSTSENSE are open drain outputs. The external pull up resistor should NOT be connected to a voltage higher than Vdd.
The abs max sink current for both are 10mA.
Hope that helps.
