Part Number: TL7705A
Other Parts Discussed in Thread: TPS37
I am trying to find technical data for part number TL7705AMJGB to compare to replacement TL7705A so I can compare if it is a Form, Fit, Function.
Hello Ron,
TL7705AMJGB is an obsoleted device and data sheet is no longer available.
If you are working a new design, I would recommend considering the new generation device such as https://www.ti.com/product/TPS37
Thanks.
How would i determine if this replacement is a Form Fit Function without the data sheet for the obsolete item?
Hello Ron,
Based on part number it appears that TL7705AMJGB had similar spec to TL7705A but was offered in a CDIP package which is no longer available.
TPS37 device mentioned above will offer similar functionality with improved performance but a design and layout change will be required.
Hope that helps.
