Other Parts Discussed in Thread: BQ27542-G1, BQSTUDIO
Hi Team,
May I check with you where can i find the srec for BQ27542-G1? Is the default srec file equipped inside the evaluation board?
Thanks.
Hi Team,
Thanks.
Hello Ernest,
The BQ27542-G1 comes preprogrammed with default firmware. You can always read out the firmware and save it.
If you want to set all visible data memory values to default, then bqStudio has a button to import default values for viewing. Write All if you want to write those values to BQ27542-G1
