TPS40170: TPS40170 Crank simulator
Part Number: TPS40170
Other Parts Discussed in Thread: LM5141
Power Supply Board TPS.pdf
Hi TI team,
We are designing the TPS40170 crank simulator.
Kindly review the Schematic and PCB circuits and let us know the your valuable feedback for improve it.
Thanks for understanding.
  • Hi Jayaraman
    Please refer my comments below.
    • If it is not too late, please consider using LM5141.
    • Traces are too thin. Please use wide copper traces. Please download https://www.ti.com/lit/ug/slvu984/slvu984.pdf and try to make the PCB layout similar with the example.
    • It is recommended to separate AGND and PGND from the schematic level.
    • Please compare your component selections with the Figure 12 and correct if any difference.
    -EL
