Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
BQ79731-Q1: Current sense setting of BQ79731-Q1 GUI
Part Number: BQ79731-Q1
Hi team,
I'm using BQ79731-Q1 GUI to test the current detect function.
And I find there is a current sense setting in the GUI.
Could you please tell me what the meaning of CS_DR and how to choose the CS_DR and the LPF_CS?
Thanks & Best Regards,
Brian
  • HI Brian,
    These two settings are to configure CS ADCs operation controls. Before starting the CS ADCs sampling, please configure the proper settings desired.
    The CS_DR is to configure the CS ADC continuous mode refresh rate( decimation ratio), and the LPF_CS is to select the post CS ADC first order digital low pass filter cut off frequency for current measurement.
