Hello guys,
One of my customers is evaluating BQ25302 on their own board for new products.
They measured EMI level of the board. As the result, the EMI level was exceeded EMI level limit around 40Mhz and 200MHz.
So they tried to add 1ohm resistor (1005 size) between BTST and SW terminal like R2 in BQ25302 EVM to reduce EMI noise.
But BQ25302 couldn't operate correctly and LED which connected to STAT terminal was blinked to inform any fault happen then.
Do you know why the fault is happened?
If you need any more information, could you please let me know?
Your reply would be appreciated.
Kazuya.
