Want to check the ID chemistry following a learning cycle with Gauging Parameter Calculator (GPC).
Unfortunately, it seems do not work correctly.
I uploaded these files:
And I received the response: "Warning: Discharge rate is too high. High rate reduces ID detection accuracy 10 hr rate is recomeended. Total discharge time is less than 5 hrs t_hrs= 0"
In our case the discharge last 7.7 hours, this should be enough to determine the good chemistry, shouldn’t it?
Can you help me on this?
