TPS2321: Troubleshooting
Part Number: TPS2321
Other Parts Discussed in Thread: TPS40054
Hi.
We have a problem with the Hot Swap Controller. If we connect the load after the Hot-Swap Controller, there is a fault by overcurrent; however, if we connect the same before the hot-swap controller, then the regulator works properly. Also, this only happens when the load is ON and the Switching Supply is Off. If we have the Switching Supply ON, and then we turn on the Load, it doesn't present any fault. We are using TPS40054 as a regulator. This starts happening after several days testing our new mosfets in the Buck Regulator.
