Hi Team,
Which thermal metric should be selected as the 2-Resistor Model in Flotherm,Rjb or Rjc(bot)?
Should the solder be created in the thermal Model between PCB and Compound if the Rjc(bot) is selected?
Thanks.
Hello Hai,
For the two-resistor model, use the junction-to-board thermal resistance RθJB and the junction-to-case (top) RθJC(top) found in the datasheet.
Ridge
Hi Isa,
Thanks for you reply.
I describe my confusion more detail in the PDF file.
Hello Hai,
If you are using the thermal pad, you will need to use a DELPHI model for the most accurate results since it can model both the leads (RθJB) and the thermal pad (RθJC(bot)). If you want to use the 2-resistor model, use the RθJB for a more conservative estimate of thermal performance.
Ridge
