Other Parts Discussed in Thread: TPS55288, , TPS65987, BQ25731
We designed 100w source/sink with TPS65987 pd controller. But operating temperature of TPS65987 is -10 to +75 but we need -30 operating temperature. When we design usb pd circuit we used TPS55288, SPI EEPROM, TPS65987, TPD6S300AR and Embedded controller. For -30 operating temperature we wanna change the pd controller from TPS65987 to TPS25750. So; we create a flow with TPS25750 and other components. Can you check this? İs there any problem to design 100W Source/100W Sink usb pd design. We don't want to use any BQ charger. You can see that in the flow. Can you check it? Can we use TPS25750 like this and programming it?
Thanks.
Şahin
