TPS25750: About VIF(Vendor Info File) of USB PD3 CTS
Guru 21045 points
Part Number: TPS25750
Hi Team,
Could you please let us know VIF(Vendor Info File) of USB PD3 CTS?
Hide
  • Good Afternoon Hide,
    I will look into your question and provide an answer on 3/23.
    Conner Gillette
  • Hi Conner-san,
    Thank you for your response.
    I’m looking forward to hearing from you.
    Hide
  • <VIF xmlns="http://usb.org/VendorInfoFile.xsd">
    <VIF_Specification>2.04</VIF_Specification>
    <VIF_App>
    <Vendor>USB-IF</Vendor>
    <Name>Vendor Info File Editor</Name>
    <Version>2.0.1.1</Version>
    </VIF_App>
    <Vendor_Name>Texas Instruments</Vendor_Name>
    <Model_Part_Number>TPS25750D</Model_Part_Number>
    <Product_Revision>A</Product_Revision>
    <TID>0</TID>
    <VIF_Product_Type value="0">Port Product</VIF_Product_Type>
    <Component>
    <Port_Label>1</Port_Label>
    <Connector_Type value="2">Type-C™</Connector_Type>
    <USB_PD_Support value="true"/>
    <PD_Port_Type value="4">DRP</PD_Port_Type>
    <Type_C_State_Machine value="2">DRP</Type_C_State_Machine>
    <Port_Battery_Powered value="false"/>
    <BC_1_2_Support value="2">Charging Port</BC_1_2_Support>
    <PD_Specification_Revision value="2">Revision 3.0</PD_Specification_Revision>
    <SOP_Capable value="true"/>
    <SOP_P_Capable value="false"/>
    <SOP_PP_Capable value="false"/>
    <SOP_P_Debug_Capable value="false"/>
    <SOP_PP_Debug_Capable value="false"/>
    <Manufacturer_Info_Supported_Port value="true"/>
    <Manufacturer_Info_VID_Port value="1105">0451</Manufacturer_Info_VID_Port>
    <Manufacturer_Info_PID_Port value="0">0000</Manufacturer_Info_PID_Port>
    <USB_Comms_Capable value="false"/>
    <DR_Swap_To_DFP_Supported value="true"/>
    <DR_Swap_To_UFP_Supported value="true"/>
    <Unconstrained_Power value="true"/>
    <VCONN_Swap_To_On_Supported value="true"/>
    <VCONN_Swap_To_Off_Supported value="true"/>
    <Responds_To_Discov_SOP_UFP value="true"/>
    <Responds_To_Discov_SOP_DFP value="true"/>
    <Attempts_Discov_SOP value="true"/>
    <Chunking_Implemented_SOP value="true"/>
    <Unchunked_Extended_Messages_Supported value="true"/>
    <Security_Msgs_Supported_SOP value="false"/>
    <Num_Fixed_Batteries value="0"/>
    <Num_Swappable_Battery_Slots value="0"/>
    <Type_C_Can_Act_As_Host value="false"/>
    <Type_C_Can_Act_As_Device value="false"/>
    <Type_C_Implements_Try_SRC value="false"/>
    <Type_C_Implements_Try_SNK value="false"/>
    <Type_C_Supports_Audio_Accessory value="false"/>
    <Type_C_Is_VCONN_Powered_Accessory value="false"/>
    <Type_C_Is_Debug_Target_SRC value="true"/>
    <Type_C_Is_Debug_Target_SNK value="true"/>
    <Captive_Cable value="false"/>
    <RP_Value value="2">3A</RP_Value>
    <Type_C_Port_On_Hub value="false"/>
    <Type_C_Power_Source value="2">Both</Type_C_Power_Source>
    <Type_C_Sources_VCONN value="true"/>
    <Type_C_Is_Alt_Mode_Controller value="false"/>
    <BC_1_2_Charging_Port_Type value="2">Both</BC_1_2_Charging_Port_Type>
    <PD_Power_As_Source value="15000">15000 mW</PD_Power_As_Source>
    <USB_Suspend_May_Be_Cleared value="true"/>
    <Sends_Pings value="false"/>
    <FR_Swap_Type_C_Current_Capability_As_Initial_Sink value="0">FR_Swap not supported</FR_Swap_Type_C_Current_Capability_As_Initial_Sink>
    <Master_Port value="true"/>
    <Num_Src_PDOs value="1"/>
    <PD_OC_Protection value="false"/>
    <SrcPdoList>
    <SrcPDO>
    <Src_PDO_Supply_Type value="0">Fixed</Src_PDO_Supply_Type>
    <Src_PDO_Peak_Current value="0">100% IOC</Src_PDO_Peak_Current>
    <Src_PDO_Voltage value="100">5000 mV</Src_PDO_Voltage>
    <Src_PDO_Max_Current value="300">3000 mA</Src_PDO_Max_Current>
    </SrcPDO>
    </SrcPdoList>
    <PD_Power_As_Sink value="60000">60000 mW</PD_Power_As_Sink>
    <No_USB_Suspend_May_Be_Set value="true"/>
    <GiveBack_May_Be_Set value="false"/>
    <Higher_Capability_Set value="true"/>
    <FR_Swap_Reqd_Type_C_Current_As_Initial_Source value="0">FR_Swap not supported</FR_Swap_Reqd_Type_C_Current_As_Initial_Source>
    <Num_Snk_PDOs value="2"/>
    <SnkPdoList>
    <SnkPDO>
    <Snk_PDO_Supply_Type value="0">Fixed</Snk_PDO_Supply_Type>
    <Snk_PDO_Voltage value="100">5000 mV</Snk_PDO_Voltage>
    <Snk_PDO_Op_Current value="90">900 mA</Snk_PDO_Op_Current>
    </SnkPDO>
    <SnkPDO>
    <Snk_PDO_Supply_Type value="2">Variable</Snk_PDO_Supply_Type>
    <Snk_PDO_Min_Voltage value="100">5000 mV</Snk_PDO_Min_Voltage>
    <Snk_PDO_Max_Voltage value="400">20000 mV</Snk_PDO_Max_Voltage>
    </SnkPDO>
    </SnkPdoList>
    <Accepts_PR_Swap_As_Src value="true"/>
    <Accepts_PR_Swap_As_Snk value="true"/>
    <Requests_PR_Swap_As_Src value="false"/>
    <Requests_PR_Swap_As_Snk value="false"/>
    <FR_Swap_Supported_As_Initial_Sink value="false"/>
    <XID_SOP value="0"/>
    <Data_Capable_As_USB_Host_SOP value="false"/>
    <Data_Capable_As_USB_Device_SOP value="false"/>
    <Product_Type_UFP_SOP value="3">PSD</Product_Type_UFP_SOP>
    <Product_Type_DFP_SOP value="0">Undefined</Product_Type_DFP_SOP>
    <Modal_Operation_Supported_SOP value="false"/>
    <USB_VID_SOP value="1105">0451</USB_VID_SOP>
    <PID_SOP value="0">0000</PID_SOP>
    <bcdDevice_SOP value="2309">0905</bcdDevice_SOP>
    <Product_Total_Source_Power_mW value="15000">15000 mW</Product_Total_Source_Power_mW>
    <Port_Source_Power_Type value="0">Assured</Port_Source_Power_Type>
    </Component>
    </VIF>
    Here is the requested file.
  • Hi Conner-san,
    Thank you for the information.
    Hide
  • Hi Conner-san,
    Our customer confirmed VIF.
    Then, the following items are blank.
    PD_Spec_Revision_Major
    PD_Spec_Revision_Miner
    PD_Spec_Version_Major
    PD_Spec_Version_Miner
    Can they apply even if this item is blank?
    If no, could you please let us know the information of Revision and Version?
    Hide
  • <PD_Specification_Revision value="2">Revision 3.0</PD_Specification_Revision> includes the major and minor revision values.
    <Version>2.0.1.1</Version> includes the major and minor version values.
    Conner Gillette
  • Hi Conner-san,
    Thank you for your prompt reply and information.
    Hide
  • Hi Conner-san,
    My understanding is below.
    Is my understanding correct?
    PD_Spec_Revision_Major=3
    PD_Spec_Revision_Miner=3
    PD_Spec_Version_Major=2.0.1.1
    PD_Spec_Version_Miner=2.0.1.1
    We understand that we can’t enter "2" into PD_Spec_Revision because VIF rule is 3 to 9.
    Therefore, we guess that PD_Spec_Revision value is 3.
    However, your comment is “<PD_Specification_Revision value="2">Revision 3.0”.
    So, we don't know if PD_Spec_Revision value is 2 or 3.
    I’d greatly appreciate your verification.
    Hide
  • My apologies, after reviewing the Vendor Info File Definition Document, the values are as follows:
    PD Specification Revision 3.0, Version 2.0:
    • PD_Spec_Revision_Major = 3
    • PD_Spec_Revision_Minor = 0
    • PD_Spec_Version_Major = 2
    • PD_Spec_Version_Minor = 0
    The Complete PD Specification Number is 3020h.
  • Hi Conner-san,
    Hide
  • Hi Conner-san,
    We have additional question.
    [Q1]
    Are there any plans for TPS25750 to support USB PD Rev3.1?
    If yes, could you please let us know when to adapt?
    [Q2]
    If TPS25750 can support USB PD Rev3.1, please let me know if you have the following information.
    - Are there any measurement items to fail?
    -Measurement items that have not been implemented
    -Measurement items that can be passed
    <Background>
    Our customer are using TPS25750 at current model.
    And, they would like to use TPS25750 for next model but need USB PD Rev3.1 and USB I/F certification.
    Therefore, they need some information.
    Hide
  • Could you post this on the internal forum Hide? I will be able to respond appropriately there.
    Conner Gillette
  • Hi Conner-san,
    I sent you a friendship request message yesterday.
    Because, I can’t find internal forum.
    Hide
  • My apologies Hide, I had erroneously thought you were a TI employee. I am checking with a colleague and will be able to answer your question by the end of the day today, in this thread.
  • Hide,
    The TPS25750 will remain PD 3.0 compliant, however we will be releasing a new product this year that will be PD 3.1 compliant. I believe your customer will find its feature-set competitive, in addition to being cost competitive.
    Kind regards,
    Conner Gillette
  • Hi Conner-san,
    I understand that TPS25750 can’t support PD3.1.
    And, could you please let us know RTM timing and detail information of a new product?
    Hide
  • That is correct.
    The new product (that will be PD 3.1 compliant) is planned to be released to ti.com for the middle of this calendar year, and RTM beginning of next year. It will have a similar feature set to the TPS25750.
    Kind regards,
    Conner Gillette
  • Hi Conner-san,
    Hide
