Hello, Sir.
We used BQ76952 for battery management of the GD32 through the I2C protocol.
I had a few problems estimating the battery SOC:
I need the voltage and current of the battery for Kalman filtering. Should the measurement of the voltage and current determine the ADSCAN bit or the FULLSCAN bit? In addition, should the current be measured using the calculated value in the synchronous voltage and current measurement or cc2?
What is the difference between the DSTATUS1 ~4() subcommand reporting in 32-bit format the raw current ADC reading and cc2 count synchronized with the battery voltage measurement?
Please ask Mr.
Thank you very much. Look for positive responses.
Greetings,
DARLUU.
