Part Number: UCD90120A
Hi Team,
The customer observed that GPIO11/PIN23 has an abnormal signal, as shown in channel 4 (red) in the figure. This will cause abnormal output of the post-stage power supply it controls (see channel 2, green). Channel 3 (blue) is the supply voltage for the UCD. Is this pulse on the enable signal(GPIO11/PIN23) normal? Whether when the IC power supply is less than a certain voltage, the output is uncertain.
Hailiang
