Hello team,
My customer would like to know BQ24765 boot strap equivalent at boot pin.
In the datasheet, there is a following block.
But I believe that there is a diode as below to turn on High side FET. Is the following equivalent circuit is correct?
Your advice is appreciated.
Akihisa Tamazaki
Hello Akihisa,
Please see Section 9.2 Typical Application. The bootstrap diode is present from VDDP to BOOT. Also the BOOT pin description says, "Connect a small bootstrap Schottky diode from VDDP to BOOT."
Mike Emanuel
Mike-san,
Thank you for your comment.
Sorry that I missed the schematics in Section 9.2 Typical Application.
Akihisa Tamazaki
