Is the gpio event mapping feature of tps25750 now available?
Thanks.
Yes, you can configure the GPIOs of the TPS25750 using the Application GUI, located at https://dev.ti.com/gallery/info/1769824/TPS25750_Application_Customization_Tool
Navigate to 'Advanced Configuration', select the Configuration tab in the top ribbon, and select 'IO Config (0x5C)'. You can use the TPS25750 Technical Reference Manual to learn how to configure the events. Specifically, Section 2.16 GPIO Events, details how each GPIO event functions.
Kind regards,
Conner Gillette
