I am using this part to monitor my LIPO battery. The Gauge needs a sense resistor in series with GND.
I have the battery mounted in some clips, that means that positive terminal and negative terminal are not together, but distanced the length of the battery.
Regarding the routing of the PCB, how do you recommend to route GND plane?
Should I place the sense resistor + Gauge as near as possible to the negative terminal and generate my GND plane from there? Or maybe route with a thick trace the negative terminal of the battery closer to the positive terminal and generate my GND plane closer to my power plane?
Thank you.
