Hello
I have small questions regarding to TPS61094 :
1. for my application i need solution - Auto Buck or Boost Mode Operation, section 7.4.5, correct, data sheet?
2. if i need Vout=5V while Vin 5V, i need set resistor between the OSEL pin and GND to R=247Kohm? no drop voltage ?
3. do you have same equation that can gave me a super capacitor size, for example, what capacitor size should be if i need Vout 5V for 7sec and current of Iout=2 Amp?
Thank you
Ilya
