HELLO,
I wanted to know how to change learned status from 6 to 2 after the end of the learning cycle
Changing from 6 to 2 is done by EVSW. It's just a feature of the software so that the gauge isn't automatically enabled after programming the golden image.
If you want to re-create this, you can do it manually as Shirish suggested. The data sheet refers to EVSW, not bqStudio and EVSW auto-changes Update Status to 2 when you export the golden image.
