I am getting a 5031 error code when I try to calibrate the voltage. The pack is unlocked and in the gas gauge mode. It is happing on just one battery pack. Any ideas what the code means?
Mike
Mike
Is this while using the mtester ? Error code 5031 means below :
ERR_CALIBRATION_IN_FIRMWARE_CCIOFF : Error in CC offset calibration, Value too large (Overflow) in firmware You can find further details here : http://focus.ti.com/lit/ug/sluu238a/sluu238a.pdf
I had to replace the BQ20Z95 chip to fix the problem.
