Hi all.
I want to turn on/off the power to a servo.
The datasheet only talks about resistor dividers on the EN and /EN pins.
What is the proper way to turn the powerswitch on and off from a microcontroller pin?
And do I still need all the resistors?
Hi all.
You can connect uc pin directly to EN /EN pins. You don't need resistors then. Just ensure that EN pin is not floating while device is having VIN supply. Resistors divider way is also a possible way where you don't need uc and use input supply.
Kunal Goel
It depends on your application. You can connect both to uc. You can also ground /EN pin, that will disable overvoltage protection feature. You can use both resistor divider and uc also.
How much max voltage servo can tolerate? Can supply voltage go beyond servo max rating?
Kunal Goel
