Is it possible to use bq2057 or similar in a 3-S configuration? Can the voltage to the batt pin be scaled down?
Any other options for an inexpensive linear charger for 3-S?
I can't go to switching- the pass transistor is already installed and controlled by an analog current. If a switching controller is the only option, I'll have to LPF the PWM to control an analog current.
Vin = 18V
Thanks.
