who to simulate QOD in Pscpice with this load switch?
Zeev Gerber
Hi Zeev,
The TPS22954 QOD is a fixed 15ohm typ resistance to ground under the following conditions:
If you remove the resistive load Rload off of the schematic in the PSpice design you can see how the output is still pulled down once EN is low:
An EVM can also be ordered here to demonstrate this functionality on silicon: https://www.ti.com/tool/TPS22954EVM?keyMatch=TPS22954%20EVM
Elizabeth
