Hello please help me selecting power path priotizer ic For Primary source supply 5.6V -4 ampere and secondary supply is battery 3.7v boosted to 5V-2ampere output.
The device will run on main supply 5.6v 4 ampere normally and when there is outage and this supply is not available the device will shift to battery boosted 5v supply.
when the battery drains it should properly turn off the device protecting the device from under voltage lockout.
Please suggest similar IC for this purpose.
