Part Number: TPS546D24S
Other Parts Discussed in Thread: TPS546D24A, , TPS546D24, TPS546B24A, TPS546B24S, TPS546A24S, TPS546A24A
I am have been using the TPS546D24A and now I see the TPS546D24S on-line, this brings up several questions?
Is the TPS546D24S compatible with TPS546D24A designs?
I know the TPS546D24 uses different pin-programming resistors than the TPS546D24A, Does the S use resistors from the TPS546D24 for the TPS546D24A?
Did anything else about the TPS546D24A change in the TPS546D24S?
What's new about the TPS546D24S?
Will the TPS546D24A be discontinued with the release of the TPS546D24S?
I don't see a TPS546B24S or TPS546A24S version on TI.com, will there be an S version of the TPS546B24A and TPS546A24A?
