Part Number: TPS61046
Other Parts Discussed in Thread: TPS61372, TPS61086
Hi Team,
Can you help to check if we have any devices spec similar to TPS61046, but with Force PWM mode only to reduce output ripple? Thanks.
Hi Jacky,
TPS61046 gets load disconnect and inner diode, if that is necessary, you can choose TPS61378 or TPS61372
if you would like small number of pins, you can choose TPS61086.
But the three cannot output voltage above 20V.
Best Regards
Fergus
