Hello expert,
About TPS7A69-Q1,you said that I_max_RES is Ilkg=1uA, can I understand that the RESET pin can only withstand a maximum current of 1uA?
Would this be too small? If I use 5V VDD to pull up and connect a 2.4KΩ resistor to the RES pin, does that mean it will damage the LDO? Because the current at this time has exceeded 1uA.
