Other Parts Discussed in Thread: LP5890
I want to design P3 RGB LED Display panel for 16x48 LED's Matrix using TLC5926. I have few questions as below,
1. What is refresh rate of TLC5926? Will it support for Video playing?
2. How to control Luminosity/Brightness?
3. R-Ext will control the current for all 16 LED's or require separate current limiting resistor for each LED?
4. What is relation between Luminosity/Brightness with SMPS power?
5. If I connect 3 panels of 16x48 RGB LED Display in series, Requirement of Luminosity/brightness is >600cd/m2 what is the power required of SMPS?
6. For Daisy Chain of TLC5926, If I connect 9 TLC5926 in series how control all 9 IC's output because all IC's have common ~OE(ED2) and LE(ED1) and SDO connected to second IC's SDI?
Mohan
