TPS7H5001-SP: LTspice model and simulation for PWM controller validation
Part Number: TPS7H5001-SP
Other Parts Discussed in Thread: PSPICE-FOR-TI
I am using TPS7H5001 and need to simulate it in LTspice.  I ran the .lib file from the Design Resources, taken from the PSpice Buck converter design.  I have errors when running this model.  Notice that with an input of 10V, the soft start voltage reaches 1.5V but the the other traces do not have data or are not plotted.
1. Can you help me determine if my circuit is correct for testing the general Datasheet behavior.  I am specifically validating for SP and PS times relative to OUTA and OUTB at approx 200kHz and how they vary with there respective resistances (SP and PS) ?
2. How do you buffer connect an OTA?  Is the shorting COMP to VSENSE correct?
3. Can you help me determine why I am seeing SRA, SRB, OUTB and OUTA collapsed?  OUTA comes up but there does not seem to be anymore data that plots.  Is it a schematic error or is it that the model does not work on LTspice ?
4. Is the model good for LTspice use or it exclusive to PSpice? ( I ran this on PSpice and the simulation crashed or did not give meaningful information)
Attachements:
1. .lib model used.
2. LTspice image of Circuit and Sim results.
3. LTspice error image
4. LTspice simulation file.  --> change the .txt extension to .asc please.
tps7h5001-sp_trans.lib
Version 4
SHEET 1 1080 20620
WIRE 592 -272 -608 -272
WIRE -80 -144 -464 -144
WIRE -48 -144 -80 -144
WIRE 32 -144 -48 -144
WIRE 352 -144 272 -144
WIRE -464 -96 -464 -144
WIRE -48 -96 -48 -144
WIRE 32 -96 -48 -96
WIRE 352 -96 272 -96
WIRE -608 -64 -608 -272
WIRE -80 -48 -304 -48
WIRE 32 -48 -80 -48
WIRE 352 -48 272 -48
WIRE -304 -16 -304 -48
WIRE 32 0 -224 0
WIRE 976 0 272 0
WIRE -464 16 -464 -16
WIRE -224 48 -224 0
WIRE 32 48 -224 48
WIRE 832 48 272 48
WIRE 976 48 976 0
WIRE -224 96 -224 48
WIRE 32 96 -224 96
WIRE 448 96 272 96
WIRE 720 96 448 96
WIRE -304 128 -304 48
WIRE -224 128 -224 96
WIRE 832 128 832 48
WIRE -48 144 -80 144
WIRE 32 144 -48 144
WIRE 592 144 592 -272
WIRE 592 144 272 144
WIRE -608 192 -608 16
WIRE -48 192 -48 144
WIRE -48 192 -608 192
WIRE 32 192 -48 192
WIRE 544 192 272 192
WIRE 592 192 592 144
WIRE 720 224 720 96
WIRE 32 240 -352 240
WIRE 352 240 272 240
WIRE -608 256 -608 192
WIRE -352 288 -352 240
WIRE 32 288 -352 288
WIRE 352 288 272 288
WIRE 32 336 -240 336
WIRE 432 336 272 336
WIRE -240 368 -240 336
WIRE -608 480 -608 336
WIRE -352 480 -352 288
WIRE -240 480 -240 448
WIRE 432 480 432 336
WIRE 544 480 544 192
WIRE 592 480 592 256
WIRE 720 480 720 288
WIRE 832 480 832 208
WIRE 976 480 976 128
FLAG -464 16 0
FLAG -304 128 0
FLAG -224 128 0
FLAG -608 480 0
FLAG -80 144 COMP
FLAG 592 480 0
FLAG 352 240 SRA
FLAG 352 288 SRB
FLAG 544 480 0
FLAG 432 480 0
FLAG -240 480 0
FLAG -352 480 0
FLAG 352 -48 OUTA
FLAG 352 -96 OUTB
FLAG 976 480 0
FLAG 352 -144 SYNC
FLAG 832 480 0
FLAG 720 480 0
FLAG 448 96 SS
FLAG -80 -144 IN
FLAG -80 -48 VLDO
SYMBOL AutoGenerated\\TPS7H5001-SP_TRANS 144 16 R0
SYMATTR InstName U1
SYMBOL voltage -464 -112 R0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value 10
SYMBOL cap -320 -16 R0
SYMATTR InstName C1
SYMATTR Value 1�
SYMBOL res -624 -80 R0
SYMATTR InstName R1
SYMATTR Value 1k
SYMBOL res -624 240 R0
SYMATTR InstName R2
SYMATTR Value 1k
SYMBOL cap 576 192 R0
SYMATTR InstName C2
SYMATTR Value 470n
SYMBOL res -256 352 R0
SYMATTR InstName R3
SYMATTR Value 50k
SYMBOL res 960 32 R0
SYMATTR InstName R4
SYMATTR Value 500k
SYMBOL res 816 112 R0
SYMATTR InstName R5
SYMATTR Value 562k
SYMBOL cap 704 224 R0
SYMATTR InstName C3
SYMATTR Value 10p
TEXT -620 568 Left 2 !.tran 0.25m
TEXT -296 -496 Left 6 ;TPS7H5001 - SP Test Circuit
TEXT -1952 -312 Left 2 !* PSpice Model Editor - Version 17.4.0\n* TPS7H5001-SP\n*****************************************************************************\n* (C) Copyright 2021 Texas Instruments Incorporated. All rights reserved.                                            \n*****************************************************************************\n** This model is designed as an aid for customers of Texas Instruments.\n** TI and its licensors and suppliers make no warranties, either expressed\n** or implied, with respect to this model, including the warranties of \n** merchantability or fitness for a particular purpose.  The model is\n** provided solely on an "as is" basis.  The entire risk as to its quality\n** and performance is with the customer\n*****************************************************************************\n*\n* This model is subject to change without notice. Texas Instruments\n* Incorporated is not responsible for updating this model.\n*\n*****************************************************************************\n*\n** Released by: Texas Instruments Inc.\n* Part: TPS7H5001-SP\n* Date: 07NOV2022\n* Model Type: TRANSIENT \n* Simulator: PSPICE\n* Simulator Version: 17.4.0.s012\n* EVM Order Number: TPS7H5001EVM-CVAL\n* EVM Users Guide: SLVUBZ8\n* Datasheet: SLVSF07\n* Verified Topologies: Push-Pull, Buck, and Flyback\n* Model Version: RevC\n*\n*****************************************************************************\n*\n* Updates:\n*\n* RevA\n* 1. Moved subcircuit models into the main model\n*\n* RevB\n* 1. Fixed bug in blanking signal\n* 2. Updated component used for blanking reset\n* 3. Improved access to internal device parameters\n*\n* RevC\n* 1. Fixed RevB bug\n*\n*****************************************************************************\n*\n* Model Usage Notes:\n*\n* 1. These features have not been modeled:\n*          - Fault delay\n*          - Thermal shutdown\n* 2. Max step size of 20n is required for valid simulation results.\n*\n*****************************************************************************\n*$\n.SUBCKT TPS7H5001-SP_TRANS VIN EN VLDO DCL HICC FAULT COMP VSENSE SP PS LEB SYNC OUTB OUTA RT RSC SS REFCAP CS_ILIM SRA SRB AVSS\n+ PARAMS: EA_gm=1800u SS_thresh=1 I_ss=2.7u \nX_U112         RES_OUTB_PLS_B EN_FROM_HICC N16663350 AND2_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_U99         N16662660 RES_OUTB_PLS N16662666 AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U79         DIS_FROM_HICC N16661660 N16661600 NOR2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nC_C_SP         0 SP  1f IC=0 TC=0,0 \nX_U77         P2 N16655464 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=8n\nX_U76         S2 N16655412 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=8n\nX_U66         S1 N16654302 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=8n\nR_R15         DCL N16642816  500k TC=0,0 \nE_E3         N16640395 0 N16640389 VSENSE 1\nE_LIMIT1         N16636926 0 VALUE {LIMIT(V(N16636920),-1m,1m)}\nR_R9         REFCAP N16635331  998.37 TC=0,0 \nX_U13         PWM_OUT N16637650 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U10         N16637752 N16637782 N16637790 BLANK_CS DIG_HI EN_FROM_HICC\n+  DFFSBRB_SHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_H2    N16639238 N16639306 N16639244 0 TPS7H5001-SP_TRANS_H2 \nR_R16         CS_ILIM N16643855  1.667k TC=0,0 \nX_U47         BLANK N16649561 SWITCH_CLOCK_PRE N16649565 AND3_BASIC_GEN PARAMS:\n+   VDD=1 VSS=0 VTHRESH=0.5\nX_U48         DCL_HI DCL_HIZ N16649561 OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_H5    N16649897 N16650431 N16650417 0 TPS7H5001-SP_TRANS_H5 \nX_U97         DIS_FROM_HICC N16662666 N16662578 NOR2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U83         DCL_HI RES_P_O BLANK_INT_B N16661924 AND3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nE_ABM68         PS_OPEN 0 VALUE { IF( V(N16655582) > 208m, 0, 1)    }\nX_U73         P2 N16655326 INV_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=1n\nE_ABM10         N16655074 0 VALUE { IF( V(N16654790) > 1, 1, 0)    }\nE_MUX3         S2_PS 0 VALUE { IF( V(PS_OPEN) < 0.5,  \n+ V(N16654960), V(N16655086))   }\nX_U67         P1 N16654356 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=8n\nX_U61         N16653960 N16653966 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5 DELAY=20n\nE_ABM60         N16653620 0 VALUE { V(REFCAP)    }\nX_U58         N16653604 VLDO DCLAMP \nX_U38         HICC_OVER_1 N16647101 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM6         N16643158 0 VALUE { IF(V(dcl_0) < 0.5,  \n+ V(DCL_CLOCK), V(VLDO))   }\nR_R13         N16642674 VLDO  500k TC=0,0 \nX_S3    BLANK_CS 0 N16636974 0 TPS7H5001-SP_TRANS_S3 \nR_R10         RT N16639306  19.7k TC=0,0 \nX_U16         N16639564 DIS_LOGIC OFF OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM50         PWM_COMP_OUT 0 VALUE { IF( V(HALF-COMP_M_SLOPE) > V(N16643805)\n+  ,  \n+ 1, 0)   }\nE_ABM56         N16649867 0 VALUE { V(REFCAP)    }\nX_U100         RES_OUTB_PLS RES_OUTB_PLS_B RES_OUTB DIG_HI N16662578 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U94         RES_OUTA_PLS_B EN_FROM_HICC N16662438 AND2_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_U81         RES_OUTA_PLS RES_OUTA_PLS_B RES_OUTA DIG_HI N16661600 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nC_C14         0 N16654732  1.015p  TC=0,0 \nE_MUX4         P2_SP 0 VALUE { IF( V(SP_OPEN) < 0.5,  \n+ V(N16655080), V(N16655112))   }\nE_ABM66         SR2 0 VALUE { V(S2_PS)    }\nG_G7         VLDO N16654732 N16654636 0 1\nX_U68         N16654732 VLDO DCLAMP \nX_S14    N16654084 0 N16653604 0 TPS7H5001-SP_TRANS_S14 \nG_G5         VLDO N16653604 N16653508 0 1\nX_U35         DISCHARGE_B CHARGE HICC_CHARGE AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U33         0 N16646553 DCLAMP \nX_S11    N16646521 0 HICC N16646553 TPS7H5001-SP_TRANS_S11 \nX_S10    HICC_CHARGE 0 N16646217 HICC TPS7H5001-SP_TRANS_S10 \nX_U17         COMP VLDO DCLAMP \nV_V1         N16635049 0 1\nV_V7         N16635859 0 1.5\nX_U42         BLANK NOT_BLANK N16649359 DIG_HI N16649275 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN_BLANK PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U55         PSP_DEL N16650133 BLANK_S OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U106         DCL_HIZ N16663086 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U89         SWITCH_CLOCK DCL_LO N16662122 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM67         OUT2 0 VALUE { V(P2_SP)    }\nE_LIMIT8         N16654750 0 VALUE {LIMIT(V(N16654744),-1m,1m)}\nE_ABM5         DCL_LO 0 VALUE { IF(V(DCL_1) < 0.5, 1, 0)    }\nE_ABM3         VLDO 0 VALUE { V(N16634959)    }\nX_S1    N16634959 0 N16635049 N16635147 TPS7H5001-SP_TRANS_S1 \nR_R6         REFCAP N16635269  1 TC=0,0 \nE_ABM2         BANDGAP_REF 0 VALUE { V(N16635331)    }\nX_U14         OSC N16639268 VCO_SQR PARAMS: Fcenter=2.00e+006 Frange=2.00e+006\n+  Vmin=0.0000e+000 Vmax=4MEG phase=0\nX_U114         P2 N16663504 S2 NOR2_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U111         N16663314 SKIP_PULSE_B N16663320 AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nE_ABM65         N16654954 0 VALUE { IF( V(N16654732) > 1, 1, 0)    }\nX_H8    N16653574 N16654702 N16654630 0 TPS7H5001-SP_TRANS_H8 \nX_U62         S1 N16654084 INV_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=1n\nE_LIMIT6         N16653632 0 VALUE {LIMIT(V(N16653626),-1m,1m)}\nX_H6    N16653496 N16653574 N16653502 0 TPS7H5001-SP_TRANS_H6 \nE_ABM59         N16653496 0 VALUE { V(REFCAP)    }\nX_U39         CHARGE N16647239 OCP_OUT DIG_HI N16647233 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U29         N16646217 VLDO DCLAMP \nE_ABM46         DCL_0 0 VALUE { IF(V(N16642770) > 1.5, 1, 0)    }\nE_ABM29         N16638233 0 VALUE { IF( V(OUT1) > 100m, 5, 0)    }\nC_C1         N16634959 0  80u IC=0 \nX_U9         SKIP_PULSE N16637900 SWITCH_CLOCK_PRE SKIP_PULSE_PRE DIG_HI\n+  EN_FROM_HICC DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U46         SWITCH_CLOCK_PRE SWITCH_CLOCK BUF_DELAY_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5 DELAY=1n\nE_LIMIT4         N16649879 0 VALUE {LIMIT(V(N16649873),-1m,1m)}\nX_U54         OUT1 OUT2 PWM_INT OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nR_R17         LEB N16650431  9.484k TC=0,0 \nX_U92         SKIP_PULSE_B N16662432 N16662370 AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nE_ABM69         SP_OPEN 0 VALUE { IF( V(N16655688) > 208m, 0, 1)    }\nE_ABM63         N16653960 0 VALUE { IF( V(N16653672) > 1, 1, 0)    }\nE_MUX1         S1_PS 0 VALUE { IF( V(PS_OPEN) < 0.5,  \n+ V(N16653842), V(N16653976))   }\nX_U27         EN_LOGIC N16645993 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nR_R14         0 N16642674  500k TC=0,0 \nX_H3    N16642764 N16642816 N16642770 N16642826 TPS7H5001-SP_TRANS_H3 \nC_C9         COMP 0  1f IC=0 \nE_ABM41         N16638351 0 VALUE { IF( V(OUT2) > 100m, 5, 0)    }\nG_G1         N16635859 SS N16635985 0 {I_SS}\nC_C8         SS 0  1f IC=0 \nX_S8    BLANK_CS 0 N16643855 0 TPS7H5001-SP_TRANS_S8 \nV_V13         N16643975 0 1.05\nX_U51         N16649667 PWM_INT BLANK_CS NAND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U110         N16663314 N16663356 SWITCH_CLOCK_B DIG_HI N16663350 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U87         BLANK_INT BLANK_INT_B INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U86         N16661924 RES_OUTA_PRE N16661590 RES_OUTA OR3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_U75         P2 N16655464 N16655112 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U64         S1 N16654302 N16653976 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM62         SR1 0 VALUE { V(S1_PS)    }\nX_U30         HICC_CHARGE N16646521 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nR_R3         N16638351 OUTB  15 TC=0,0 \nR_R5         N16634959 N16634953  250m TC=0,0 \nX_U2         SS_PD N16635995 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nE_ABM43         OSC 0 VALUE { IF( V(off) <0.5, 2* LIMIT( 112000/ ( {V(REFCAP)}/\n+  (V(N16639244)*1k) )*1k, 100k, 2MEG), 0)    }\nX_U56         P1_SP P2_SP N16650125 OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U104         SWITCH_CLOCK_B DIG_HI N16662988 AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U102         SWITCH_CLOCK SWITCH_CLOCK_B INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U78         RES_P_O DCL_HIZ BLANK_INT_B N16661590 AND3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_S16    N16655194 0 N16654732 0 TPS7H5001-SP_TRANS_S16 \nE_LIMIT7         N16654636 0 VALUE {LIMIT(V(N16654630),-1m,1m)}\nG_G6         VLDO N16653672 N16653632 0 1\nE_LIMIT5         N16653508 0 VALUE {LIMIT(V(N16653502),-1m,1m)}\nE_E4         N16640407 0 N16640401 0 {EA_gm}\nR_R1         N16638233 OUTA  15 TC=0,0 \nE_ABM13         N16639274 0 VALUE { LIMIT( V(N16639268), 1, 0) * 5    }\nX_U22         PWM_COMP_OUT EN_FROM_HICC PWM_OUT AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nE_ABM51         N16643961 0 VALUE { IF( V(N16643855) > V(N16643975) ,  \n+ 1, 0)   }\nX_U43         SYS_CLOCK SWITCH_CLOCK_PRE DCL_CLOCK OR2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nC_C12         0 N16649927  1.011p  TC=0,0 \nX_U98         OUT2 N16662660 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U84         N16661856 OCP_OUT RES_P_O OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nR_R18         PS N16655664  8.858k TC=0,0 \nX_H11    N16654760 N16655714 N16655688 0 TPS7H5001-SP_TRANS_H11 \nX_H10    N16654702 N16655664 N16655582 0 TPS7H5001-SP_TRANS_H10 \nE_ABM61         N16653836 0 VALUE { IF( V(N16653604) > 1, 1, 0)    }\nX_S12    HICC_PD 0 HICC 0 TPS7H5001-SP_TRANS_S12 \nV_V2         N16642826 0 1\nE_ABM1         HALF-COMP_M_SLOPE 0 VALUE { ( V(N16636974)*-4.2657+  \n+ V(COMP)*0.5 )   }\nX_U11         DCL_CLOCK N16637790 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM44         RT_PRESENT 0 VALUE { IF(V(N16639244) > 60.65n, 1, 0)    }\nC_C_RT         0 RT  1f IC=0 TC=0,0 \nX_U20         VLDO_GOOD N16641690 N16641548 DIS_LOGIC NAND3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_S7    FAULT 0 N16641852 N16641886 TPS7H5001-SP_TRANS_S7 \nX_U21         N16641852 N16641690 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U24         BLANK_CS N16643985 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U49         N16649565 N16649681 BLANK_INT OR2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nC_C_LEB         0 LEB  1f IC=0 TC=0,0 \nX_U90         SKIP_PULSE SKIP_PULSE_B INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U80         RES_OUTA_PLS N16661838 N16661660 AND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U72         S2 N16655194 INV_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=1n\nX_U70         N16654954 N16654960 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5 DELAY=20n\nX_H7    N16653620 N16653642 N16653626 0 TPS7H5001-SP_TRANS_H7 \nX_U34         DISCHARGE DISCHARGE_B N16646929 DIG_HI HICC_OVER_0P3 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_S9    HICC_TRIG 0 VLDO HICC TPS7H5001-SP_TRANS_S9 \nI_I1         VLDO N16646217 DC 80u  \nC_C10         0 DCL  1f  TC=0,0 \nE_ABM45         N16640389 0 VALUE { IF( V(SS) < V(BANDGAP_REF),    \n+ V(SS), V(BANDGAP_REF) )   }\nC_C2         0 N16636974  15.5p IC=0 TC=0,0 \nE_E1         N16636914 0 REFCAP 0 1\nV_V11         DIG_HI 0 5\nR_R8         N16635331 0  1k TC=0,0 \nX_U3         EN_LOGIC N16635995 N16635985 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM8         SS_DONE 0 VALUE { IF((V(SS) > {SS_thresh}), 1, 0)    }\nR_R11         0 N16641548  1 TC=0,0 \nR_R12         0 N16641852  1 TC=0,0 \nX_U45         SWITCH_CLOCK_PRE N16649203 SYS_CLOCK N16649203 EN_LOGIC DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nE_ABM57         N16650075 0 VALUE { IF( V(N16649927) > 1, 1, 0)    }\nX_S13    N16650133 0 N16649927 0 TPS7H5001-SP_TRANS_S13 \nX_U107         N16663086 N16663130 EN_FROM_HICC N16663136 AND3_BASIC_GEN\n+  PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U71         N16655074 N16655080 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5 DELAY=20n\nX_U69         N16654790 VLDO DCLAMP \nC_C3         0 N16653672  1.015p  TC=0,0 \nE_MUX2         P1_SP 0 VALUE { IF( V(SP_OPEN) < 0.5,  \n+ V(N16653966), V(N16654002))   }\nX_U59         N16653672 VLDO DCLAMP \nX_U28         DIS_FROM_HICC EN_FROM_HICC INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM52         SS_PD 0 VALUE { V(DIS_FROM_HICC)    }\nE_LIMIT2         N16640401 0 VALUE {LIMIT(V(N16640395),-83m,83m)}\nR_R7         N16635147 0  1 TC=0,0 \nX_S2    N16636189 0 SS 0 TPS7H5001-SP_TRANS_S2 \nX_U12         N16637650 N16637752 BLANK_CS SKIP_PULSE_PRE AND3_BASIC_GEN\n+  PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nE_E2         N16639238 0 REFCAP 0 1\nX_U6         SYNC N16639420 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_S6    EN 0 N16641548 N16641580 TPS7H5001-SP_TRANS_S6 \nV_V12         N16643805 N16643855 150m\nX_U23         N16643961 N16643985 OCP_OUT AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM58         LEB_OPEN 0 VALUE { IF( V(N16650417) > 208m, 0, 1)    }\nX_U109         N16663136 N16663320 N16663068 P2 AND3_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U108         DCL_HI N16663130 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U103         RES_P_O N16662988 BLANK_INT_B N16662972 AND3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_U74         S2 N16655412 N16655086 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_S15    N16654216 0 N16653672 0 TPS7H5001-SP_TRANS_S15 \nE_ABM64         OUT1 0 VALUE { V(P1_SP)    }\nX_U36         HICC_TRIG N16646929 HICC_OVER_0P6 DIG_HI N16647061 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nI_I2         N16646553 0 DC 1u  \nE_ABM53         HICC_OVER_1 0 VALUE { IF( V(HICC)>1, 1, 0)    }\nE_ABM48         DCL_1 0 VALUE { IF(V(N16642770) > 0.5, 1, 0)    }\nE_TABLE2         N16635269 0 TABLE {V(N16634959)} 200mV    1mV  \n+ 1.4V        1.225V  \n+ 15.6V      1.23V\nE_ABM12         SYS_CLOCK 0 VALUE { IF(V(RT_present)>0.5, V(N16639274),\n+  V(N16639420) )  \n+     }\nX_U15         RT_PRESENT N16639564 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U52         N16649927 VLDO DCLAMP \nG_G4         VLDO N16649927 N16649879 0 1\nX_U95         P1 N16662560 S1 NOR2_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U85         OUT1 N16661838 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nE_ABM7         DCL_MASK 0 VALUE { IF(V(dcl_1) < 0.5,  \n+ V(SWITCH_CLOCK), V(N16643158))   }\nX_U18         0 COMP DCLAMP \nE_ABM42         N16638411 0 VALUE { IF( V(SR2) > 100m, 5, 0)    }\nX_U5         N16636974 VLDO DCLAMP \nX_U4         N16635995 EN_LOGIC N16636189 NAND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U19         VLDO_GOOD N16641690 N16641548 EN_LOGIC AND3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nR_R19         SP N16655714  8.858k TC=0,0 \nG_G8         VLDO N16654790 N16654750 0 1\nX_U63         P1 N16654216 INV_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\n+  DELAY=1n\nX_U60         N16653836 N16653842 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5 DELAY=20n\nE_ABM54         HICC_OVER_0P6 0 VALUE { IF( V(HICC)>0.6, 1, 0)    }\nX_U26         HICC_ON N16645993 DIS_FROM_HICC OR2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nE_LIMIT3         N16640413 0 VALUE {LIMIT(V(N16640407),-190u,190u)}\nE_ABM40         N16638293 0 VALUE { IF( V(SR1) > 100m, 5, 0)    }\nC_C11         0 N16643855  100f IC=0 TC=0,0 \nX_U53         DCL_LO BLANK N16649681 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_H4    N16649867 N16649897 N16649873 0 TPS7H5001-SP_TRANS_H4 \nX_U57         N16650125 N16650133 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U82         PWM_OUT N16661856 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nC_C13         0 N16653604  1.015p  TC=0,0 \nX_U40         NOT_BLANK EN_LOGIC N16647233 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U32         OCP_OUT N16646713 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nE_ABM49         DCL_HIZ 0 VALUE { IF(V(DCL_1)*(1-V(DCL_0)) > 0.5,  \n+ 1, 0)   }\nX_S5    SS_PD 0 COMP 0 TPS7H5001-SP_TRANS_S5 \nG_G3         VLDO COMP N16640413 0 1\nG_G2         VLDO N16636974 N16636926 0 1\nE_TABLE1         N16634953 0 TABLE {V(VIN)} 200mV    1mV  \n+ 5.1V        5V  \n+ 15.6V      5.002V\nX_U1         SS N16635859 DCLAMP \nX_S4    RT_PRESENT 0 N16639274 SYNC TPS7H5001-SP_TRANS_S4 \nV_V5         N16641580 0 1\nV_V4         N16641886 0 1\nX_U113         SS_DONE EN_FROM_HICC DCL_LO N16663504 NAND3_BASIC_GEN PARAMS: \n+  VDD=1 VSS=0 VTHRESH=0.5\nX_U105         DCL_MASK N16663068 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U101         DCL_HIZ N16662972 DCL_HI RES_OUTB OR3_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U93         N16662432 N16662444 SWITCH_CLOCK DIG_HI N16662438 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U88         BLANK_INT_B N16662122 RES_P_O RES_OUTA_PRE AND3_BASIC_GEN PARAMS:\n+   VDD=1 VSS=0 VTHRESH=0.5\nC_C4         0 N16654790  1.015p  TC=0,0 \nX_H9    N16653642 N16654760 N16654744 0 TPS7H5001-SP_TRANS_H9 \nX_U31         HICC_PD N16646719 DISCHARGE_B DIG_HI N16646713 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U25         HICC_ON N16645989 HICC_OVER_0P6 DIG_HI HICC_OVER_0P3 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nE_E5         N16642764 0 N16642674 0 1\nR_R4         N16638411 SRB  15 TC=0,0 \nX_U50         BLANK_INT N16649667 INV_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U96         SS_DONE EN_FROM_HICC N16662560 NAND2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nX_U91         EN_FROM_HICC N16662370 DCL_MASK P1 AND3_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nC_C_PS         0 PS  1f IC=0 TC=0,0 \nX_S17    N16655326 0 N16654790 0 TPS7H5001-SP_TRANS_S17 \nX_U65         P1 N16654356 N16654002 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nX_U37         EN_LOGIC N16647101 N16647061 AND2_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5\nE_ABM55         HICC_OVER_0P3 0 VALUE { IF( V(HICC)>0.3, 1, 0)    }\nE_ABM47         DCL_HI 0 VALUE { IF(V(DCL_0)*V(DCL_1) > 0.5,  \n+ 1, 0)   }\nR_R2         N16638293 SRA  15 TC=0,0 \nX_H1    N16636914 RSC N16636920 0 TPS7H5001-SP_TRANS_H1 \nE_ABM4         VLDO_GOOD 0 VALUE { IF(V(N16635147)>0.5, 1, 0)    }\nX_U44         BLANK_RESET DIS_LOGIC N16649275 NOR2_BASIC_GEN PARAMS:  VDD=1\n+  VSS=0 VTHRESH=0.5\nE_MUX         PSP_DEL 0 VALUE { IF( V(LEB_OPEN) < 0.5,  \n+ V(N16650075), V(N16650125))   }\nX_U115         BLANK_RESET N16685413 PSP_DEL DIG_HI N16685409 DIG_HI\n+  DFFSBRB_RHPBASIC_GEN_BLANK PARAMS:  VDD=1 VSS=0 VTHRESH=0.5\nX_U116         PSP_DEL N16685409 INV_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5 DELAY=20n\nX_U117         SYS_CLOCK N16649359 BUF_DELAY_BASIC_GEN PARAMS:  VDD=1 VSS=0\n+  VTHRESH=0.5 DELAY=20n\n.ENDS TPS7H5001-SP_TRANS\n*$\n.subckt TPS7H5001-SP_TRANS_H2 1 2 3 4  \nH_H2         3 4 VH_H2 1\nVH_H2         1 2 0V\n.ends TPS7H5001-SP_TRANS_H2\n \n.subckt TPS7H5001-SP_TRANS_H5 1 2 3 4  \nH_H5         3 4 VH_H5 100k\nVH_H5         1 2 0V\n.ends TPS7H5001-SP_TRANS_H5\n \n.subckt TPS7H5001-SP_TRANS_S3 1 2 3 4  \nS_S3         3 4 1 2 _S3\nRS_S3         1 2 1G\n.MODEL         _S3 VSWITCH Roff=1G Ron=1 Voff=0.2 Von=0.8\n.ends TPS7H5001-SP_TRANS_S3\n \n.subckt TPS7H5001-SP_TRANS_S14 1 2 3 4  \nS_S14         3 4 1 2 _S14\nRS_S14         1 2 1G\n.MODEL         _S14 VSWITCH Roff=1G Ron=1.0 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S14\n \n.subckt TPS7H5001-SP_TRANS_S11 1 2 3 4  \nS_S11         3 4 1 2 _S11\nRS_S11         1 2 1G\n.MODEL         _S11 VSWITCH Roff=1G Ron=100 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S11\n \n.subckt TPS7H5001-SP_TRANS_S10 1 2 3 4  \nS_S10         3 4 1 2 _S10\nRS_S10         1 2 1G\n.MODEL         _S10 VSWITCH Roff=1G Ron=100 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S10\n \n.subckt TPS7H5001-SP_TRANS_S1 1 2 3 4  \nS_S1         3 4 1 2 _S1\nRS_S1         1 2 1G\n.MODEL         _S1 VSWITCH Roff=1G Ron=1f VH=0.075 VT=3.475 TD=0\n.ends TPS7H5001-SP_TRANS_S1\n \n.subckt TPS7H5001-SP_TRANS_H8 1 2 3 4  \nH_H8         3 4 VH_H8 1\nVH_H8         1 2 0V\n.ends TPS7H5001-SP_TRANS_H8\n \n.subckt TPS7H5001-SP_TRANS_H6 1 2 3 4  \nH_H6         3 4 VH_H6 1\nVH_H6         1 2 0V\n.ends TPS7H5001-SP_TRANS_H6\n \n.subckt TPS7H5001-SP_TRANS_H3 1 2 3 4  \nH_H3         3 4 VH_H3 -200k\nVH_H3         1 2 0V\n.ends TPS7H5001-SP_TRANS_H3\n \n.subckt TPS7H5001-SP_TRANS_S8 1 2 3 4  \nS_S8         3 4 1 2 _S8\nRS_S8         1 2 1G\n.MODEL         _S8 VSWITCH Roff=100MEG Ron=100m Voff=0 Von=1\n.ends TPS7H5001-SP_TRANS_S8\n \n.subckt TPS7H5001-SP_TRANS_S16 1 2 3 4  \nS_S16         3 4 1 2 _S16\nRS_S16         1 2 1G\n.MODEL         _S16 VSWITCH Roff=1G Ron=1.0 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S16\n \n.subckt TPS7H5001-SP_TRANS_H11 1 2 3 4  \nH_H11         3 4 VH_H11 100k\nVH_H11         1 2 0V\n.ends TPS7H5001-SP_TRANS_H11\n \n.subckt TPS7H5001-SP_TRANS_H10 1 2 3 4  \nH_H10         3 4 VH_H10 100k\nVH_H10         1 2 0V\n.ends TPS7H5001-SP_TRANS_H10\n \n.subckt TPS7H5001-SP_TRANS_S12 1 2 3 4  \nS_S12         3 4 1 2 _S12\nRS_S12         1 2 1G\n.MODEL         _S12 VSWITCH Roff=1G Ron=100 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S12\n \n.subckt TPS7H5001-SP_TRANS_S7 1 2 3 4  \nS_S7         3 4 1 2 _S7\nRS_S7         1 2 1G\n.MODEL         _S7 VSWITCH Roff=1e6 Ron=1f VH=0.05 VT=0.55 TD=10n\n.ends TPS7H5001-SP_TRANS_S7\n \n.subckt TPS7H5001-SP_TRANS_H7 1 2 3 4  \nH_H7         3 4 VH_H7 1\nVH_H7         1 2 0V\n.ends TPS7H5001-SP_TRANS_H7\n \n.subckt TPS7H5001-SP_TRANS_S9 1 2 3 4  \nS_S9         3 4 1 2 _S9\nRS_S9         1 2 1G\n.MODEL         _S9 VSWITCH Roff=1G Ron=4k Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S9\n \n.subckt TPS7H5001-SP_TRANS_S13 1 2 3 4  \nS_S13         3 4 1 2 _S13\nRS_S13         1 2 1G\n.MODEL         _S13 VSWITCH Roff=100MEG Ron=1.0 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S13\n \n.subckt TPS7H5001-SP_TRANS_S2 1 2 3 4  \nS_S2         3 4 1 2 _S2\nRS_S2         1 2 1G\n.MODEL         _S2 VSWITCH Roff=100MEG Ron=250 VH=0 VT=0.5 TD=10n\n.ends TPS7H5001-SP_TRANS_S2\n \n.subckt TPS7H5001-SP_TRANS_S6 1 2 3 4  \nS_S6         3 4 1 2 _S6\nRS_S6         1 2 1G\n.MODEL         _S6 VSWITCH Roff=1e6 Ron=1f VH=0.05 VT=0.55 TD=10n\n.ends TPS7H5001-SP_TRANS_S6\n \n.subckt TPS7H5001-SP_TRANS_S15 1 2 3 4  \nS_S15         3 4 1 2 _S15\nRS_S15         1 2 1G\n.MODEL         _S15 VSWITCH Roff=1G Ron=1.0 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S15\n \n.subckt TPS7H5001-SP_TRANS_H4 1 2 3 4  \nH_H4         3 4 VH_H4 1\nVH_H4         1 2 0V\n.ends TPS7H5001-SP_TRANS_H4\n \n.subckt TPS7H5001-SP_TRANS_S5 1 2 3 4  \nS_S5         3 4 1 2 _S5\nRS_S5         1 2 1G\n.MODEL         _S5 VSWITCH Roff=7MEG Ron=10 Voff=0 Von=1\n.ends TPS7H5001-SP_TRANS_S5\n \n.subckt TPS7H5001-SP_TRANS_S4 1 2 3 4  \nS_S4         3 4 1 2 _S4\nRS_S4         1 2 1G\n.MODEL         _S4 VSWITCH Roff=1G Ron=1f Voff=0 Von=1\n.ends TPS7H5001-SP_TRANS_S4\n \n.subckt TPS7H5001-SP_TRANS_H9 1 2 3 4  \nH_H9         3 4 VH_H9 1\nVH_H9         1 2 0V\n.ends TPS7H5001-SP_TRANS_H9\n \n.subckt TPS7H5001-SP_TRANS_S17 1 2 3 4  \nS_S17         3 4 1 2 _S17\nRS_S17         1 2 1G\n.MODEL         _S17 VSWITCH Roff=1G Ron=1.0 Voff=0.0V Von=1.0V\n.ends TPS7H5001-SP_TRANS_S17\n \n.subckt TPS7H5001-SP_TRANS_H1 1 2 3 4  \nH_H1         3 4 VH_H1 100m\nVH_H1         1 2 0V\n.ends TPS7H5001-SP_TRANS_H1\n*****************************************************************************\n*$\n.SUBCKT AND2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  &  \n+ V(B) > {VTHRESH},{VDD},{VSS})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS AND2_BASIC_GEN\n*$\n.SUBCKT AND3_BASIC_GEN A B C Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  &  \n+ V(B) > {VTHRESH} &\n+ V(C) > {VTHRESH},{VDD},{VSS})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS AND3_BASIC_GEN\n*$\n.SUBCKT NAND2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  &  \n+ V(B) > {VTHRESH},{VSS},{VDD})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS NAND2_BASIC_GEN\n*$\n.SUBCKT NAND3_BASIC_GEN A B C Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  &  \n+ V(B) > {VTHRESH} &\n+ V(C) > {VTHRESH},{VSS},{VDD})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS NAND3_BASIC_GEN\n*$\n.SUBCKT OR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  |  \n+ V(B) > {VTHRESH},{VDD},{VSS})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS OR2_BASIC_GEN\n*$\n.SUBCKT OR3_BASIC_GEN A B C Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  |  \n+ V(B) > {VTHRESH} |\n+ V(C) > {VTHRESH},{VDD},{VSS})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS OR3_BASIC_GEN\n*$\n.SUBCKT NOR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  |  \n+ V(B) > {VTHRESH},{VSS},{VDD})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS NOR2_BASIC_GEN\n*$\n.SUBCKT INV_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \nE_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH} , \n+ {VSS},{VDD})}}\nRINT YINT Y 1\nCINT Y 0 1n\n.ENDS INV_BASIC_GEN\n*$\n.SUBCKT INV_DELAY_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 DELAY = 10n \nE_ABMGATE1    YINT1 0 VALUE {{IF(V(A) > {VTHRESH} , \n+ {VDD},{VSS})}}\nRINT YINT1 YINT2 1\nCINT YINT2 0 {DELAY*1.3}\nE_ABMGATE2    YINT3 0 VALUE {{IF(V(YINT2) > {VTHRESH} , \n+ {VSS},{VDD})}}\nRINT2 YINT3 Y 1\nCINT2 Y 0 1n\n.ENDS INV_DELAY_BASIC_GEN\n*$\n.SUBCKT BUF_DELAY_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 DELAY = 10n \nE_ABMGATE1    YINT1 0 VALUE {{IF(V(A) > {VTHRESH} , \n+ {VDD},{VSS})}}\nRINT YINT1 YINT2 1\nCINT YINT2 0 {DELAY*1.44}\nE_ABMGATE2    YINT3 0 VALUE {{IF(V(YINT2) > {VTHRESH} , \n+ {VDD},{VSS})}}\nRINT2 YINT3 Y 1\nCINT2 Y 0 1n\n.ENDS BUF_DELAY_BASIC_GEN\n*$\n.SUBCKT DFFSBRB_RHPBASIC_GEN Q QB CLK D RB SB PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \n***Set has higher priority in this\n** Changed the delay from 7n/10n to 15n/20n to help larger time step simulations\n**Faster flip-flops require a a smaller time step to simulate\nX1 CLK CLKdel INV_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 15n\nX2 CLK CLKdel CLKint AND2_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} \nGQ 0 Qint VALUE = {IF(V(RB) < {VTHRESH},-5,IF(V(SB)< {VTHRESH},5, IF(V(CLKint)> {VTHRESH}, \n+ IF(V(D)> {VTHRESH},5,-5),0)))}\nCQint Qint 0 1n\nRQint Qint 0 1000MEG\nD_D10 Qint MY5 D_D1\nV1 MY5 0 5\nD_D11 0 Qint D_D1 \nEQ Qqq 0 Qint 0 1\nX3 Qqq Qqqd1 BUF_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 20n\nRQq Qqqd1 Q 1\nEQb Qbr 0 VALUE = {IF( V(Q) > {VTHRESH}, {VSS},{VDD})}\nRQb Qbr Qb 1 \nCdummy1 Q 0 1nF \nCdummy2 QB 0 1nF \n.IC V(Qint) {VSS}\n.ENDS DFFSBRB_RHPBASIC_GEN\n*$\n.subckt DCLAMP A C\nG1 A C TABLE { V(A, C) } ( (-1,-1n)(0,0)(1m,1) (2m,10) (3m,1000) )\n.ends DCLAMP \n*$\n.MODEL D_D1 D( IS=1e-15 TT=10p Rs=0.001 N=.1  )\n*$\n.SUBCKT DFFSBRB_RHPBASIC_GEN_BLANK Q QB CLK D RB SB PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \n**Faster flip-flops require a a smaller time step to simulate\nX1 CLK CLKdel INV_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 10n\nX2 CLK CLKdel CLKint AND2_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} \nGQ 0 Qint VALUE = {IF(V(RB) < {VTHRESH},-5,IF(V(SB)< {VTHRESH},5, IF(V(CLKint)> {VTHRESH}, \n+ IF(V(D)> {VTHRESH},5,-5),0)))}\nCQint Qint 0 1n\nRQint Qint 0 1000MEG\nD_D10 Qint MY5 D_D1\nV1 MY5 0 5\nD_D11 0 Qint D_D1 \nEQ Qqq 0 Qint 0 1\nX3 Qqq Qqqd1 BUF_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 1p\nRQq Qqqd1 Q 1\nEQb Qbr 0 VALUE = {IF( V(Q) > {VTHRESH}, {VSS},{VDD})}\nRQb Qbr Qb 1 \nCdummy1 Q 0 1nF \nCdummy2 QB 0 1nF \n.IC V(Qint) {VSS}\n.ENDS DFFSBRB_RHPBASIC_GEN_BLANK\n*$\n.SUBCKT DFFSBRB_SHPBASIC_GEN Q QB CLK D RB SB PARAMS: VDD=1 VSS=0 VTHRESH=0.5 \n***Set has higher priority in this\n** Changed the delay from 7n/10n to 15n/20n to help larger time step simulations\n**Faster flip-flops require a a smaller time step to simulate\nX1 CLK CLKdel INV_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 15n\nX2 CLK CLKdel CLKint AND2_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH}\nGQ 0 Qint VALUE = {IF(V(SB) < {VTHRESH},5,IF(V(RB)<{VTHRESH},-5, IF(V(CLKint)> {VTHRESH}, \n+ IF(V(D)> {VTHRESH},5,-5),0)))}\nCQint Qint 0 1n\nRQint Qint 0 1000MEG\nD_D10 Qint MY5 D_D1\nV1 MY5 0 {VDD}\nD_D11 MYVSS Qint D_D1\nV2 MYVSS 0 {VSS} \nEQ Qqq 0 Qint 0 1\nX3 Qqq Qqqd1 BUF_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 20n\nRQq Qqqd1 Q 1\nEQb Qbr 0 VALUE = {IF( V(Q) > {VTHRESH}, {VSS},{VDD})}\nRQb Qbr Qb 1 \nCdummy1 Q 0 1nF \nCdummy2 QB 0 1nF \n.IC V(Qint) {VSS}\n.ENDS DFFSBRB_SHPBASIC_GEN\n*$\n.subckt VCO_SQR in out PARAMS: Fcenter=2.00e+006  Frange=2.00e+006  Vmin=0 Vmax=4MEG phase=0 \nRin             in              0               1G\nRtable  table   0               1G\nEtable  table   0       Value {Table(V(in),Vmin,-1,Vmax,1)}\nEsin            sine            0               \n+Value {sin(6.28318*(Fcenter*time+Frange*SDT(V(table)))+phase*(3.14159/180))}\nEsqr            out             0               table {V(sine)} (0,0) (1n,1)\n.ends vco_sqr\n*$
  • Hi Jorge,
    This model was developed for use in PSpice there can be difficulties using it in other SPICE simulators due to syntax differences between tools. The error logs you've shared confirms this, though I think none of the visible error messages should be fatal to the sim. Using PSpice-for-TI is an additional workaround since the tool is free and includes the model and example circuits for this device.
    It looks like you are using the latest revision (Rev C), but based on the simulation command shown on your schematic the simulation step size has not been specified. Please be aware that this model requires a step size of 20ns in order to accurately capture/sample the switching signals that are produced. This is noted in the lib file header (and in the on-schematic notes if using the PSpice project).
    Can you try adjusting the step size of your sim to see if that resolves the main issue?
    Sarah
