Other Parts Discussed in Thread: TPS65987, TPS65987D
We are using TPS65987DDJ for UFP and ALT mode.
We are trying to load the patch bundle from Host through I2C Referenced from /cfs-file/__key/communityserver-discussions-components-files/196/5100.SPI_5F00_Less_5F00_EC_5F00_Based_5F00_Host_5F00_Programming_5F00_Over_5F00_I2C_5F00_slva972a.pdf
Low region array is generated from TPS65987 App config GUI tool for UFP.
We are using following HW configuration.
We are facing following issues:
We are using TPS65987DDJ chip but while reading dev info reg (0x2f) shows T P S 6 5 9 8 8 H W 0 0 3 0 F W F 8 0 7 . 1 2 . 0 0 Z A c e 1 is it OK?
" PTCs " and " PTCd " commands are getting success response.
" PTCq " Command response gives following results
noDevicePatch is set
noApplicationConfigPatch is set
DevicePatchSource is none
ApplicationConfigurationPatchSource is from I2C
" PTCc " Command response gives following results
- AppConfigPatchCompleteStatus is Success
- DevicePatchComplete Status is Patch not compatible with this version of ROM (0x42)
How to resolve this and loading patch bundle successfully?
Can you please provide exact procedure to apply patch bundle through I2C from host. and how to validate it
Srini
