Other Parts Discussed in Thread: TPS541620
Hi All,
The Device TPSM5D1806 has a pin called BP5 which as per the data sheet is a 5 V nominal (Range = 4.8 V to 5.2 V) regulated output.
My question is :
If I use Vin = 5 V, can the BP5 will still provide 5 V regulated output or is there any lower limit on Vin for which BP5 may not be active as a regulator ??
Also what is the drive capability of BP5 as a regulator ?
