Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LP5861: Time-Multiplexing Matrix Scheme
Part Number: LP5861
Hello everyone,
I have a confusion on how LP5861 drives LEDs through its high-side PMOS output. From datasheets, Other LP586x ICs except LP5861 are using Time-Multiplexing Matrix Scheme when driving LEDs through their high-side PMOS outputs. Which means each high-side output cannot continuously turned on. Instead, there will be a specific "ON" time and "OFF" time. For LP5861 this Time-Multiplexing Matrix Scheme is not stated in the datasheet. It is kind of obvious actually, since LP5861 only has one high-side output. But does it mean that LP5861 high-side output can be turned on continuously without specific "ON" time and "OFF" time? Can someone confirm this for me?
Thank you in advance.
