Other Parts Discussed in Thread: PMP22806, TPS23731
Hi all,
I have a question regards using the TPS23734 in my design. I have already analysed PMP23278B application note for designing an ACF converter, but I am wondering if there is an option to slightly change the design into a flyback converter. There is no need to run synchronous rectification on the secondary side in my design.
As far as I understand, to make this possible, it is required by simply change the transformer (suited for flyback topologies), and disable GAT2 output.
I am wondering if that’s correct. Can I ask you to help me clear this up?
Best regards, Andrzej
