Other Parts Discussed in Thread: LP5813, LP5861, LP5018
I am using two LP55231 to control 6 RGB LEDs.
When I turn on all LEDs with max brightness, both ICs heat up to more than 80 degrees celsius. I stopped the testing as I didn´t want to burn the ICs.
My custom board has a constrained space (30x30mm).
Is a 4 layer board with the Thermal vias of the ICs connected to 2 internal GND planes.
I also tested the LP55231 development board from Sparkfun (link) with slightly better results (70 degrees celsius with max brightness setting). This is still pretty high for my application.
Is this a typical behavior for this IC? Is there anything I could do to reduce this heat?
Thank you very much for your help!
