Hi Team,
Greetings for the day.
We are using the TPS7A9201 LDO in our Layout Board file. I had attached the images of the Board file and Schematics. Please review the layout and share your feedback with us.
The PCB we are using is of 12 Layers:
IC and discrete parts - Place on Bottom
Layers 2,4,9 and 11 are Ground
Thanks and regards
- Teja.
Hello Teja,
I reviewed both schematic and layout. Some suggestions regarding the layout:
1. Make the vias on the thermal pad as small as possible and add as many as possible.
2. Connect GND plane from thermal pad to Pin 4 and make it bigger (like top side) to improve thermals.
3. C416, R450 and R453 bring them as near as possible to the LDO by moving R472 a little further away. For optimization is better to have closer loops.
4. Make the ground of C429 bigger.
5. Why is the FB35 used?
Eunize Tobias
