TLV759P: Thermal via layout
Part Number: TLV759P
Hi All,
I have a question about TLV759P.
The layout guidelines state that thermal vias should not be installed.
However, vias are listed in the LAND PATTERN.
Which is correct?
Ishiwata
  • Hi Ishiwata-san,
    It is true that vias directly beneath the thermal pad will wick some solder away. With that said, we regularly recommend putting the vias directly under the thermal pad, so I don't know why it was stated to not do so. Thermal performance will be best with them directly beneath the package. If that is a concern to you, the board manufacturer can fill the vias with copper so that there isn't a cavity to wick solder away.
    Nick
