is there any application note or design tool for -ve output design from this module. can use for -15v, 1A output
Yes, it can be used working as inverting buck-boost. For the specific design process, you can refer to the two ANs in the attachment. Hope this can help you. Thanks.
Create an Inverting Power Supply Using Peak Current Mode Buck Converter.pdf
Working with Inverting Buck_Boost Converters.pdf
Aurora
I will close this thread due to no reply for a long time. If you have other questions in the future, you can ask them again in E2E. Thanks.
Aurora
