For the LV2862, what does it do if it is not operating (in SHDN or Vin absent) and you back feed power to the output?
For example, say LV2862 makes 5 volts from a higher voltage source. Another power supply makes 5.5 volts and diode mixes that on the output of the LV2862 circuit. Will the LV2862 tolerate that?
To say it another way, what is the LV2862 output leakage?
I can design the circuit with a diode in the LV2862 output, but would prefer to eliminate the cost and efficiency loss of that diode. An ideal diode is straight out for cost reasons.
Thanks.
