Part Number: BQ25792
Could you tell me more about past questions.
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1130790/bq25792-about-tdie_adc-accuracy/4197496?tisearch=e2e-quicksearch&keymatch=bq25792%20TDIE#4197496
>Therefore, the higher bit readings shifted higher to correct for the 12-bit setting issue. A new datasheet revision just posted that states that the 12-bit setting is no longer recommended.
Customer want to measure TDIE before charging to avoid charging outside the temperature range.
As in the past post, the TDIE reading is lower than the outside temperature.
Please let me know the recommended usage of ADC_TDIE.
I want to improve the phenomenon that the temperature is detected low and measure the accurate DIE temperature.
And I would like to know the update information about DIE_ADC accuracy.
Best regards
Yusuke
