BQ24075-Q1: Questions for bq24075-Q1 in parallel application to support higher charging current
Part Number: BQ24075-Q1
Hi Team,
Customer wants to check if we can use 2pcs bq24075-Q1 in parallel to support maximum 3A charging current, as we do not find any Q1 version charging IC with power path feature in our products, can you help to check if it will be achievable or not? Below is the brief block diagram, please help to give us some suggestions. Thanks.
