UC3825BN driving mosfets of push pull converter
Other Parts Discussed in Thread: TL494
Hello
I am using uc3825bn for driving mosfets of push pull converter. When I tried and tested (on bread board) the open loop configuration given in the datasheet, I got perfect outputs on the pins 11 and 14 with desired dead time between them. But on many occasions the outputs on this pins weren’t stable the disappeared without any reason. Also I used polyester capacitors rather than ceramic since they have steady capacitance. And when I interfaced it to power circuit the all the waveforms were distorted including the PWM pulses from pins 11 and 14. Can anybody help me in this regard as what needs to be done?
Thank you.
