Hello TI,
I am planning on using the TPS1663 in an upcoming design. Do you have any data on the zero point accuracy of the IMON output?
The datasheet specifies some values that equate to a roughly +/-8% accuracy in terms of gain, but there is no mention of offset. Being able to detect true 'zero' current is important for this application. Do you have any data on the output current range of IMON at zero current through the device?
Thank You!
