Hi ,
when i read the TPS1h000 datasheet, i noticed there is a maximum of 100uA loss of ground output leakage current. i am not so clear about what's the meaning of loss of ground output leakage current. do you mean you applied voltage between OUT pin and GND pin to measure the current flow between OUT pin and GNd pin ?
