When measuring the phase margin, should I put Ri (injection resistor) in front of the FB resistor as shown in the figure below and measure it with FRA?
Since LM5180 supports PSR flyback operation, you cannot use the standard injection resistor method. Instead, you will need to run a load transient step and correlate the appropriate phase and gain margin with the resulting voltage waveform. You may use this app note: www.ti.com/.../slva381b.pdf
Richard
Dear Richard san
Thank you for your strong support !
I understood.
Miyata
