TPSI3052-Q1: Spice model.
Part Number: TPSI3052-Q1
Hello All,
I am vivek woking as an engineer in EATON, i am using this SSR in my application. Is it good to use for Silicon Mosfets for fast turn on/Off. If not is there any alternate IC similar to this.
And do we have spice library model which works in all type simulation softwares.?
Vivek Gandham
  • Hello Vivek,
    Once you have selected the MOSFET, you can check the calculation tool (SLVRBI9C.ZIP) found under the TPSI3052-Q1 product page here and see if the turn on/off time meets your desired specifications.
    We only support Pspice for simulation models.
    Tilden Chen
    Solid State Relays | Applications Engineer
