battery charger
I want to test your products like TPS61322DBZR, TPS61299XDRLR, TLV61046A, TPS61322DBZR, TPS61240DRVT . I will use these products with a battery charger integrated. The system I want to build will be as follows; I want to make a system like usb(5v)--> battery charger --->pil -->boost converter(5v). I aim that the system I will design in this way does not shut down and remains open all the time. Can you suggest me a battery charger and boost converter that I can work with?
We also know that Lipo batteries should not drop below 3.5V. The battery I will use will be a li-po battery, can you get back to me about it? I want a battery charger and boost converter that I can use in Li-po batteries.
