While programming TPS53659RSBR using a customer data file, there is a checksum mismatch after issuing the MFR_SERIAL command (the last command in the customer data file). The expected checksum is 0x412DEB8CF, but the checksum read out is 0x412DEB8CB. The register values are read out correct.
Would you please give insights on why the checksum mismatch happens?
Thanks!
